[SOLVED] [v2.15.1] Decal times management
Hi there!,
I the last version of Unigine the LifeTime and FadeTime of decals had been removed so, How do you manage now the behaviours that were ruled by those times?
Thanks alot!
Thanks sweetluna,
But if I have a water decal to simulate a shoot impact over the water, how could I fade away the decal?
1) Inherit your decal material
2) Assign it to the newly created splash decal
3) Change some alpha parameter that is defined in your material
For decal_base material:
For graph based decals (no water decal support yet) add some kind of "global alpha" parameter and use it instead:
Some useful API reference links:
https://developer.unigine.com/en/docs/2.15.1/api/library/rendering/class.material?rlang=cpp#setParameterFloat_int_float_void
https://developer.unigine.com/en/docs/2.15.1/api/library/rendering/class.material?rlang=cpp#inherit_Material
Hope this helps!
  • Thanks 1
  • silent changed the title to [SOLVED] [v2.15.1] Decal times management
