hongguang.li Posted July 17 Share Posted July 17 How to capture motion blur image at runtime? if (player == null) { Unigine.Console.OnscreenMessageLine(vec4.RED, "No active camera."); return; } viewport.Mode = Render.ViewportMode; // We temporarily set exposure adaptation time to 0, otherwise the image may be too dark float exposureAdaptation = Render.ExposureAdaptation; Render.ExposureAdaptation =0f; // We render with velocity buffer turned off to avoid temporal effects artifacts viewport.AppendSkipFlags(Viewport.SKIP_VELOCITY_BUFFER); viewport.RenderImage2D(player.Camera, image, width, height); viewport.RemoveSkipFlags(Viewport.SKIP_VELOCITY_BUFFER); Render.ExposureAdaptation = exposureAdaptation; if (!alphaChannel || format == Format.jpg) { if (image.Format == Image.FORMAT_RGBA8) { image.ConvertToFormat(Image.FORMAT_RGB8); } else if (image.Format == Image.FORMAT_RGBA16F) { image.ConvertToFormat(Image.FORMAT_RGB16F); } } image.Save(fullName_yuan, 1); In this way, the images are clear,Motion blur effect cannot be intercepted。 Link to comment
sweetluna Posted July 18 Share Posted July 18 Hi hongguang.li, This is happening due to empty velocity buffer for the new viewport. You can try swapping textures around so you won't end up copying it. Try calling your code from the above in Render.CALLBACK.END_SCREEN for main viewport: Render.AddCallback(Render.CALLBACK_INDEX.END_SCREEN, MakeScreenShot); But don't forget to add a check for current viewport to prevent recursion: public void MakeScreenShot() { if (Render.Viewport == vp) return; // Store velocity texture velocity = Renderer.TextureGBufferVelocity; // Your code goes here } And add another callback: private void swap_velocity_texture() { Renderer.TextureGBufferVelocity.swap(velocity); } then add it to the viewport vp.AddCallback(Render.CALLBACK_INDEX.BEGIN_SCREEN, swap_velocity_texture); vp.AddCallback(Render.CALLBACK_INDEX.END_SCREEN, swap_velocity_texture); Hope this helps! 1 May RenderDoc/Nsight Graphics/Intel GPA bless you Link to comment
