Gmarquez Posted July 15, 2022 Share Posted July 15, 2022 Hi there Team. I'm switching an application prototype from 2.4.1 to 2.15.1 to know what I must to change in our set of simulators build in the old 2.4.1 version, and I'm getting and compile time error in one of your header files UnigineBase.h template <class F> struct YCombinator { template <class... Args> decltype(auto) operator()(Args&&... args) const { return f(std::ref(*this), std::forward<Args>(args)...); } F f; } In this code the compiler sais that type auto must to be an expression not a type. Also in the next template <class F> YCombinator<std::decay_t<F>> makeRecursiveLambda(F &&f) { return [std:forward<F>(f)}; } Compiler sais that std::decay_t don't belong to std I don't know what could be happening but I gess that it could be because the C++ version. We are using C++11, What are the C++ version supposed to be used with the v2.15.1 of Unigine? Link to comment
bmyagkov Posted July 15, 2022 Share Posted July 15, 2022 Hello! Quote I don't know what could be happening but I gess that it could be because the C++ version. We are using C++11, What are the C++ version supposed to be used with the v2.15.1 of Unigine? @Gmarquez At the moment with the SDK 2.15.1 we are on C++14 and plan to keep it for a while for sure. Looks like your issue should be solved at the same time as you switch from C++11. You can also might try to add following line at the top of the UnigineBase header: #include <type_traits> Thanks! 1 Link to comment
Gmarquez Posted July 15, 2022 Author Share Posted July 15, 2022 (edited) 1 hour ago, bmyagkov said: Hello! @Gmarquez At the moment with the SDK 2.15.1 we are on C++14 and plan to keep it for a while for sure. Looks like your issue should be solved at the same time as you switch from C++11. You can also might try to add following line at the top of the UnigineBase header: #include <type_traits> Thanks! Thank you, it works. It didn't worked, At first sight it looks like worked but somehow the sim_linux version swithced to 2.4.1, I don't know why. Once the sim_linux version get fixed to the 2.15.1, the error comes again Edited July 15, 2022 by Gmarquez Link to comment
bmyagkov Posted July 15, 2022 Share Posted July 15, 2022 3 hours ago, Gmarquez said: Thank you, it works. It didn't worked, At first sight it looks like worked but somehow the sim_linux version swithced to 2.4.1, I don't know why. Once the sim_linux version get fixed to the 2.15.1, the error comes again Check out UnigineBase header again. If you are upgraded your project from 2.4.1 to 2.15.1 then includes files might be overwritten by the default one. The most correct way to solve the issue would be switch to C++14 instead of using C++11 since there might be a lot of the other places which requires fixes to make things works again without switching :) P.S If you're using cmake then you need to add the following line to the CMakeLists.txt: set(CMAKE_CXX_STANDARD 14) And for QT based project standard should be switched here: Thanks! 1 Link to comment
