dongju.jeong Posted June 8 Share Posted June 8 (edited) I tested about projection settings. However, warping does not apply. I setting syncker in ig_confing like <syncker_channels> <channel view_id="0" use_syncker_projection="1" syncker_name="projector0"/> <channel view_id="1" use_syncker_projection="0" syncker_name="add_cam"/> </syncker_channels> and set projections configration. and set command line. [ -sync_master 1 -sync_count 1 -sync_view projector0 ] Debug information is as follows result screen( didn't warping) Edited June 9 by dongju.jeong Link to comment
cash-metall Posted June 10 Share Posted June 10 Hi! you need to add AppProjection plugin to startup -extern_plugin "IG,AppProjection" 1 Link to comment
dongju.jeong Posted June 13 Author Share Posted June 13 thank you. I didn't even think about it I hope there is that comment on the IG template document page. Link to comment
dongju.jeong Posted June 13 Author Share Posted June 13 Hi, I have one more question. In order to set exactly half the brightness of part in blending, should I set it to alpha 0.5 and contrast 0.0? (or alpha 0.5, contrast 0.5?) Link to comment
silent Posted June 14 Share Posted June 14 There is no strict requirements, adjust visually so there would be no seams visible in blending area. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
