Editor crashes on certain Node References (2.15.1)
I noticed that Node References, which are containing only another Node Reference, are causing an editor crash:
- If you select such a Node Reference in the Asset Browser, the Editor will crash (sometimes with delay)
- If you try to drag & drop such a Node Reference into the Viewport, the Editor will crash
- If you drag & drop such a Node Reference with multiple other Node References, the Editor will not crash (you can edit the Node Reference normally)
- If you place another Node Reference in the Viewport and change the Node via Paramters tab -> Reference -> Name to such an Node Reference, the editor will not crash (you can edit the Node Reference normally)
I think this is an bug, since we haven´t observed this behaviour before.
Kind regards
Edited by ShadowZelda
Hi ShadowZelda,
Thank you for your bug report. We successfully reproduced this crash, and will fix it in the upcoming update.
Thanks
