ulf.schroeter Posted September 14, 2010 Share Posted September 14, 2010 Proposal addition of a clear command for clearing console output history Reason When using commands like system_analyse etc. the console history growth quite quickly. Clearing the history between calls would be helpfull. Link to comment
ulf.schroeter Posted October 24, 2010 Author Share Posted October 24, 2010 We have implemented clear command as additional build-in console command like ls, toggle, bind/unbind and exposed it to UNIGINE script as engine.console.clear(). Also fixed uninitalized empty line color_id value in WidgetConsole::WidgetConsole(), which might cause crashes in void WidgetConsole::render() due to invalid color array access void WidgetConsole::render() { ..... render_text(0,getFontSize() * i,colors[lines[index].color_id],lines[index].line.get(),0,0); ..... } Updated source files console.h/.cpp and GuiInterpreter.cpp send to Alexander, maybe he is willing to include it into UNIGINE distribution. Link to comment
frustum Posted October 25, 2010 Share Posted October 25, 2010 Thanks. Console clear command is implemented. But instead of engine.console.clear() function use engine.console.run("clear") function. Link to comment
ulf.schroeter Posted October 25, 2010 Author Share Posted October 25, 2010 But instead of engine.console.clear() function use engine.console.run("clear") function. yep, this is more consistent, thanks ! Link to comment
