kmmun1 Posted January 27, 2022 Share Posted January 27, 2022 Hello Unigine :D We have a hand lag issue in Unigine 2.11.0.2 We just rebuild with “AppVarjo_double_x64” plugin (with no source code changing) but our hand having a lag issue [ Video 1 ] before before.mp4 [ Video 2 ] after (with no source code changing) after.mp4 I wonder about : Is there any confilct Varjo plugin or Leap motion plugin with Unigine And our hand having a lag issue If there’s any issue in plugin we missed, please give us a advice Thank you! our environment : Varjo XR - 3 & VR - 3 Unigine 2.11.0.2 Leap motion 4.1.0 Link to comment
kmmun1 Posted February 24, 2022 Author Share Posted February 24, 2022 Hello Unigine :D last month I asked the problem but we still didn’t find the way To solve this problem, we used AppVive.dll into Varjo VR-3 & XR-3 (not AppVarjo.dll) but we still have delay problem I want to know is : Why the delay problem occur and wonder how to make it better Thank you! our environment : i9-9900k RTX-3090 Used dll (image file : AppVarjo.dll & AppVive.dll) Link to comment
silent Posted February 24, 2022 Share Posted February 24, 2022 kmmunInno Hard to understand what's going on. If you don't have any lags with default AppVarjo plugin it would mean that after rebuilding plugin it's not working as intended. In 2.11 SDK we used following environment to build this plugin: Varjo SDK 1.3.x (Latest available from June, 2019) Microsoft Visual Studio 2015 (19.0.24215.1) Windows SDK: 10.0.18363 You can try to rebuild plugin using this environment. Also, you need to remove all your changes in AppVarjo (if any) to do some clean tests. Also, I can see that you are using your own LeapMotion implementation, so it's impossible to predict how your code will work. If you can provide a small test for reproduction with step-by-step instruction, we can probably try to reproduce this first on our side. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
