Manipulate emission intensity more complex
Maybe this something very obvious but I just wasn't able to find out.
I try to manipulate the emission inentsity based on some time based functions. It wasn't really a problem to do this using simple expressions within the UnigineEditor. But I now lack of the possibility of doing some more complex stuff. Is there a possibility of referencing a script or similar there? I want to use it within a .node file if that makes any difference.
awagener
In this field you can use only a simple expressions, no script references or whatsoever. However, you still can write your own complex logic separately via code and execute it in runtime.
Another possible solution - you can create similar material in node-based material graph editor and animate it as you want using built-in nodes.
