[SOLVED] Translucency not working when adding albedo map
Hello everyone! I created an Albedo texture with an alpha channel. In the alpha channel, I load the Opacity map. But when I add Albedo to the material, the glasses don't become transparent. Please tell me what could be wrong.
messerrvv
You also need to adjust the transparent preset (for example, to Alpha Blend) in the material settings:
After that you can control transparency by adjusting alpha value of the Albedo in the material parameters:
  • silent changed the title to [SOLVED] Translucency not working when adding albedo map
