angus Posted January 10, 2022 Share Posted January 10, 2022 https://developer.unigine.com/en/docs/2.15/principles/render/sequence gives a 404 for all the images. Link to comment
fox Posted January 10, 2022 Share Posted January 10, 2022 Hi Angus, Seems like You're missing a trailing slash in the URL, should be: https://developer.unigine.com/en/docs/2.15/principles/render/sequence/ This way it should work as expected. In case this broken link is from the docs, please provide the location and we'll fix that ASAP. Thanks! Link to comment
