steve3d Posted August 31, 2011 Share Posted August 31, 2011 currently, the script engine only output the script error with error message, sometime it will output the error position in world script, but the line number are sometimes wrong. and the error message never said which line in which file if there are some files included with world script, you'll never know which file has some errors. this makes debugging script a very hard work, like this error message 17:25:24 Variable::getFloatSafe(): can't convert mat4 to float 17:25:24 World::update(): world update function return 0 I know this comes from which script file, but I never know which line has the error. Hope this can be improved. it will save a looot time when creating scripts. Link to comment
manguste Posted September 5, 2011 Share Posted September 5, 2011 The line is not specified, because it is not a compile-time error but rather a run-time one. Check console for disassembly information. You can also break the application at the error point, to check the call stack. Plus, there's a world_disassemble console command available. Link to comment
frustum Posted February 16, 2014 Share Posted February 16, 2014 Run-time and compilation-time errors will print same information (source line, file and line number) only for debug builds. Link to comment
