PostMaterials in 2.15-beta
In 2.15-alpha, there was a function called Unigine::Render::getPostMaterials(). Apparently, this function got removed in 2.15-beta.
Is there an alternative to get the postmaterials in 2.15-beta+ ?
Thanks
Hi Karim,
Yeah, this method was removed. Now everything is called Scriptable material. So you need to use following methods:
You can find full API changeset in migration section: https://developer.unigine.com/en/docs/future/upgrade/migration_api?rlang=cpp
  • Thanks 1
Ok thank you. I will try this out.
I have noticed that getName for materials has been removed. I think the best replacement is getGUID, right? But can getManualName be a temporary replacement for now?
Thanks
getManualName can only return name of the base material (for example, mesh_base) or manual material. If that's what you need - you can use it.
If you want to get the name of any material, it's now become a bit complicated (it's being taken directly from filename now):
const UGUID &file_mat_guid = Unigine::FileSystem::getGUID(mat->getPath());
const UGUID &asset_guid = Unigine::FileSystemAssets::resolveAsset(file_mat_guid);
const Unigine::String &virtual_path = Unigine::FileSystem::getVirtualPath(asset_guid);
const Unigine::StringStack<> material_filename = Unigine::String::filename(virtual_path);
  • Thanks 1
Yeah, I too feel this should be in the migration guide, or better in the documentation... or even better a new API function that does exactly that. We too have code that search for a specific material name on a surface to tweak its parameters at run-time.
