karim.salama Posted December 7, 2021 Posted December 7, 2021 Hi, In a class deriving from Unigine::Plugin, there is an init function with the following code : QObject::connect(Editor::Selection::instance(), &Editor::Selection::changed, &on_selection_changed); Apparently, Editor::Selection::instance() returns nullptr. I have tried changing Unigine::Plugin into Editor::Plugin, (by the way, what's the difference?) Editor::Selection::instance() still returns nullptr, I get the following error and the editor crashes. EnginePlugins::addPlugin(): "test_plugin" plugin compilation flags (Double-Release) do not match the engine ones (Double-Debug) Am I missing something? Thanks in advance
victor Posted December 7, 2021 Posted December 7, 2021 Unigine::Plugin is for extending Engine functionality. Editor::Plugin is for Editor. These plugins have different life cycles. There are steps of Editor's initialization: You launch Editor. It loads and initializes Engine. Engine loads and initializes a lot of things and Engine's plugins too (Unigine::Plugin). Then Editor initializes a lof of its own subsystems and Editor::Selection subsystem too. And at the end Editor initializes its plugins (Editor::plugins). Quote Editor::Selection::instance() returns nullptr You call this function when Editor didn't initialize its subsystems yet. Quote EnginePlugins::addPlugin(): "test_plugin" plugin compilation flags (Double-Release) do not match the engine ones (Double-Debug) I suspect you added your "test_plugin" plugin by using this command "-extern_plugin test_plugin" to launch Editor. This command is only for Engine and only for loading Engine plugins. You just need to copy your plugin file here: %project%/bin/editor — for Release build; %project%/bin/editor_debug — for Debug build; Please look at this link for more information: https://developer.unigine.com/en/docs/future/editor2/extensions/custom_plugin?rlang=cpp#plugin_run To build a good Editor's plugin you should enable using of the Qt Meta-Object compiler (moc). It's necessary to inject a meta information of your plugin class into your plugin file. In CMake it's done by using one command: set(CMAKE_AUTOMOC TRUE) # Enable automatic handling for moc. 1
karim.salama Posted December 7, 2021 Author Posted December 7, 2021 Ok thanks this is much clearer now. Yes, you are right, I was using the argument -extern_plugin. It would be nice if the engine can take the plugin folder (.../bin/editor) as an argument. Thank you
victor Posted December 8, 2021 Posted December 8, 2021 Hi, The Engine doesn't work with Editor's plugins and vice-versa. The plugin folder for Editor is hard-coded now. I guess in the future we will allow to change it. Thanks 1
