michal Posted November 9, 2021 Share Posted November 9, 2021 Hello, I would like to change the way the grass moves in the wind. The grass movement looks good, except that in zero wind the grass is still moving. ( region and meteo call setWindSpeed ) Is it possible to somehow modify this behavior, so that at zero wind speed the grass stops moving completely (using properties of the ig-plugin ) ? Thank you Link to comment
cash-metall Posted November 10, 2021 Share Posted November 10, 2021 Hi! perhaps you need to add call functions: Render::setAnimationScale(0); Render::setAnimationWind(vec3::ZERO); to stop the animation completely. ig sets these parameters on average for all layers. 1 Link to comment
michal Posted November 10, 2021 Author Share Posted November 10, 2021 (edited) Thank you for your reply. That's exactly what I'm doing , I'm using 2 layers ( the same result I got when I iterated through all layers with getRegions(). With decreasing value I observed using getAnimationScale() when the value is around 0.00001 the scale is internally set to 1 which caused the movement of the grass. So you should not to exceed the given threshold. I used setAnimationSteam() to not animate the grass in this case . Michal Edited November 10, 2021 by michal Link to comment
