christian.wolf2 Posted November 9, 2021 Share Posted November 9, 2021 Hi, I am currently trying to import an .fbx-file at runtime in C# but the documentation lacks a bit of more information to do that in C# :). I have tried to follow this topic, but currently doesn't understand, what the problem was. I have used the engine version 2.14.1.1. As usual, I register my FBX-Importer via -extern_plugin and try to do the following: public NodeReference LoadFileTo(String dataPath, String workspaceDirectory) { if (!bValidImportFile) return null; //var node_name = importer.OutputFilepath; var node_name = Import.DoImport(dataPath,workspaceDirectory); if (node_name != string.Empty) { //try to create a NodeReference try { NodeReference nodeRef = new NodeReference(node_name); return nodeRef; } catch (Exception e) { Log.Message("Import Failure."); Log.MessageLine(e.Message); } } return null; } Unfortunately I got an error message: ERROR: FbxImporter::init(): can't initialize "E:/Unigine/Monitoring_Tool_Client/data/.runtimes/18/18fd1b8b0ad5bb6e3fb54bf51fd46cd01de359ef.node" ERROR: Fbx: Unexpected file type ERROR: Importer::init: Can't init importer. I have tried it with absolute and relative path, but without any effect. When I call "Import.GetSupportedExtensions" the collection returns "FbxImporter", so this shouldn't be a problem here. The fbx-file, of course, loaded without any issues in the editor. Do I miss something up before calling "Import.DoImport"? When doing that in C++ in other projects I need to create a new Importer, where I can define additional paramers as well. Maybe I am missining something important here? A short hint would be much appreciated. Best Christian Link to comment
silent Posted November 10, 2021 Share Posted November 10, 2021 Hi Christian, Try to use "asset://" + dataPath instead of dataPath. Looks like this file has been already imported before, so now it's being threated like an asset. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
christian.wolf2 Posted November 10, 2021 Author Share Posted November 10, 2021 Thanks for the hint silent, removing the .fbx file from the data folder (was there for testing reasons) did the trick. Never thought from the error log about that could be an issue. I guess the line "can't initialize ... .node" was the hint for the already existing .fbx. file. Link to comment
