leon.fuchs Posted October 21, 2021 Share Posted October 21, 2021 Hello, is it possible to zoom with the HTC Vive? and when yes how ? I tried it with: vr_player->getPlayer()->setFov() but it does not work. Best wishes Link to comment
rohit.gonsalves Posted October 22, 2021 Share Posted October 22, 2021 Dear @leon.fuchs, What are you doing is the only option I see. Please check if your FOV mode is Vertical FOV than Physically based FOV. Use getFovMode(). Change it to desired mode using setFovMode() When mode is FOV_MODE_VERTICAL you can set vertical degrees FOV in degrees using setFov(). When mode is FOV_MODE_PHYSICALLY_BASED_CAMERA you can set horizontal FoV using setFocalLength() and setFilmGate() (horizontal sensor size). Try it it should work. Rohit Link to comment
leon.fuchs Posted October 22, 2021 Author Share Posted October 22, 2021 Hello @rohit.gonsalves , I already tried that, the mode is vertical in my case. I've also tried running it in fov_physical_based_mode, but unfortunately that doesn't work either. The zoom of the VR glasses unfortunately does not change with either of the two variants. Leon Link to comment
silent Posted October 22, 2021 Share Posted October 22, 2021 leon.fuchs There is no easy way to do correct binocular vision (is that what you are trying to achieve, right?) in VR since each HMD has it's own projection matrices for each eye. They are hardcoded for each VR plugin since each HMD is working with only a very specific FOV. mat4 left_projection = getUnigineMatrix(hmd->GetProjectionMatrix(vr::Eye_Left, znear, zfar)); mat4 right_projection = getUnigineMatrix(hmd->GetProjectionMatrix(vr::Eye_Right, znear, zfar)); If you will be able to change this value it will be quite obvious that it's not good approach. But if you want to experiment with that I can send you required plugin source code. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
leon.fuchs Posted October 22, 2021 Author Share Posted October 22, 2021 Hallo @silent, If you could send me the successful plugin source code that would be very nice. Thanks Link to comment
