Set Camera to Two Point Perspective
Is it possible to set the camera to two point perspective? I am currently working on an archviz project and want to use two point perspective for both still renderings and for a flythrough video.
Many thanks,
Ben
Hi Ben,
You can use attached scriptable material as a workaround:
Import it to your project via drag and drop into the asset browser and then go to the Settings -> Scriptable Materials and press Add New Scriptable Material button.
After that drop imported .basemat to the empty newly created empty material and inherit from it, After that you need to adjust shift parameter to something like 0.5 and move camera that way so the vertical lines will become parallel to camera.
  • Like 2
Hi Silent,
Thank you for getting back to me so promptly - and thanks for the scriptable material, I'll give it a go!
