Surface height in given point (x,y)
Hello!
I have a mesh with number of surfaces. How can I get height of the given surface in the given point (x,y)?
You can use engine.world.getIntersection() ray casts. Place start and and end point at your (x,y) with start point z above mesh bounding box z max and end point z below mesh bounding box z min.
  • 8 years later...
Hello!
how to get all the coordinates of the points of intersection of the surface with a given ray?
Using the GetIntersection function you can get only the first intersection point with an object or a list of all objects. But you can use multiple rays instead of one ray:
void get_intersection_points(Vec3 p1, Vec3 p2, int mask, Vector<vec3> &points)
    points.clear();
    WorldIntersectionPtr intersection = WorldIntersection::create();
    Vec3 direction = (p2 - p1).normalize();
    ObjectPtr hitObject = World::getIntersection(p1, p2, mask, intersection);
    while (hitObject)
        points.append(intersection->getPoint());
        p1 = intersection->getPoint() + direction * UNIGINE_EPSILON;
