mesh mask on grass
I want to apply a mesh mask to the grass.
(this is i made and imported mesh)
But the position and size of the mesh doesn't work as I intended.
I can't find a specific reason or solution, so I'm asking.
I made fbx by 3ds max and use plane
plz tell how fix it
thank you
There are two main issues with your mesh:
  • .mesh file inside FBX is being rotated 90 degrees
  • pivot point of the mesh is located in the middle, but should be located at the bottom left
In attachment you can find an example of correct .mesh file that can be used as grass mask. grass_01.mesh
