Gravity doesn't appear in track editor
           When I add gravity to the particles And after reloading the project the gravity doesn't appear to affect the particles and shown in the image below...
After reloading the project
Hello DK2312,
This happens cause wrong api func was used in tracker scripts. We'll fix it in next release
As a temporary workaround you can fix this in your project by replacing malfunctioning script.
Please replace file "node.parameters" located at "%SDK_DIR%\data\core\systems\tracker\parameters\" with the one attached. After that put the whole "core/" folder into "data/" folder of your project and remove old core.ung.
Sorry for the inconvenience caused
node.parameters
@vvvaseckiy,
Once @DK2312 places the modified file in the SDK_DIR, and he just do update configuration between Development and Release, I guess Core.ung will be built again for that project. Won't it?
Then probably he don't need to put the core folder in his project.
Rohit
  • Thanks 1
