How to close Depth of Field in my Scene?
Hi all, I'm a newer for unigine. I got an airport scene but I found that performance of the scene is dim ---- distance is farther, performance is dimmer.
I know it calls "Depth of Field", how to modify it?
Link to post
Dear @RAARRR,
Quote
What do you mean by "dim"?
Quote
May you show some screen shot to understand dimmer?
Rohit
Link to post
3 hours ago, rohit.gonsalves said:
Dear @RAARRR,
Rohit
Well, like the below:
Distance to camera, more farther and more vaguer. I want to close the effect.
Link to post
It doesn't really look like a DOF issue, but more like an anisotropic mipmap filtering issue.
Link to post
Yes, I found DOF is closed in the secen, how can I solute this issue?
I just modifyed Anisotropy in Material Panel, but looks like no effect.
Link to post
Check if you have a global settings for anisotropy (not just for this texture). It is probably globally disabled or set too low.
I can't help you more as you have an older version.
Link to post
That just the version is too old, Thanks!
Link to post
Usually it is a Setting in the Engines preferences, and/or you set it in the graphic card driver settings. Best.
Link to post
