[SOLVED] Change property value is not saved to file from Editor
I have property with this header:
<property version="2.14.0.0" name="characters" guid="aa908a40ba515918f9d5edbdcad8ebc1fe5c2b42">
That have child with this header:
<property version="2.14.0.0" name="player" guid="889c6853a117aca83ef9d6523335dc065213ae86" parent="aa908a40ba515918f9d5edbdcad8ebc1fe5c2b42">
When i try change any value in Parameters window in editor selected from Property Hierarchy, then this change is never saved to file. I try do save world and result is same.
Why Editor don't save this change?
Thanks
Honya
Link to post
honya
Do you have any errors in console after or in the process of world saving? Can you also reproduce this behavior in an empty project?
Our QA guys are currently trying to reproduce this behavior and more likely we would need some additional time for that due to 2.14.1 update schedule.
Link to post
Hello Honya,
It seems that at some point mismatch of guids happened in your project. We'll improve validation of .meta's for this case. Meanwhile, as workaround you can try to cleanup .meta for properties and reimport them, simply remove "*.prop.meta" files from data when editor is closed, and then launch editor.
Sorry for the inconvenience caused
Link to post
delete "*.prop.meta" files helps and now is change in prop saved after change in editor.
Thanks
Honya
Link to post
  • silent changed the title to [SOLVED] Change property value is not saved to file from Editor
