songtao.han Posted April 22, 2021 Share Posted April 22, 2021 While I'm coding with syncker and component systems, this question comes into my mind. There are some objects should be syncked in the scene. All these objects got a component. I'm wondering that if the components are just excuted on master? Link to comment
cash-metall Posted April 22, 2021 Share Posted April 22, 2021 Hello. if I understand correctly, you are using SynckerPlugin and C# ComponentSystem. The ComponentSystem knows nothing about the Syncker. The Syncker knows nothing about the Component System. Now the C# Component System runs on both master and slave. do you want the component system to work only on the master? or to keep the components in sync? if you want to turn off the component system in SysyemLogic call https://developer.unigine.com/en/docs/2.14/api/library/common/logic/component_system/cs/class.componentsystem?rlang=cpp#setEnabled_bool_void if syncker is initialized as a slave. if you want to synchronize the state of the components, you can use on the master send messageshttps://developer.unigine.com/en/docs/2.14/api/library/plugins/syncker/class.synckerinterface?rlang=cs#sendMessage_cstr_Blob_int_bool subscribe and read on the slavehttps://developer.unigine.com/en/docs/2.14/api/library/plugins/syncker/class.synckerinterface?rlang=cs#setMessageReceivedCallback_cstr_CallbackBase_ptr_void what messages will be - you decide. You can make save/restore state methods for each component and send data in each frame, or send only the necessary data at the time of change. both use cases are good. it is important to remember that the synker synchronizes the state of the nodes, and sometimes this can be overkill. you can make high-level commands - and send them to the slave to do the same. this can reduce the load on the network. 2 Link to comment
songtao.han Posted April 22, 2021 Author Share Posted April 22, 2021 Thanks! That is very helpful. Link to comment
