adrian.licuriceanu Posted April 16, 2021 Share Posted April 16, 2021 Hello, As we upgrade to Unigine 2.13 (from 2.5) we've encountered this problem with the new particles: Desired behaviour:- We want to be able to randomly spawn particles on surface of a mesh and then these to spread horizontally along side the mesh triangles. Simple test case for Unigine 2.13: - Create a plane - Create a particles node, attach it as child of the plane - Select Emitter shape: Random - Select Direction after emission as between (-1, -1, 0) and (1, 1, 0) Result: So, while the particles are spawned on the plane surface they are not moving. Looking over the code I can see their direction over time is cancelled by the direction of the emitter which take the plane normal as its value: In Particles::spawn_particle: if (direction_over_time_modifier->getMode() < ParticleModifier::MODE_CURVE) { vec3 instant_direction; direction_over_time_modifier->getValue(instant_direction, 0.0f, direction_lerp_coef); instant_direction.normalizeValid(); mul(emitter_direction, instant_direction, direction); mul3(emitter_direction, emitter_transform, emitter_direction); } direction_over_time_modifier correctly returns random horizontal values but direction is 0, 0, 1 and they are cancelled out. This spawn_particle is called from spawn_particles: mat3 emitter_irotation = inverse(mat3(emitter_transform)); for (int i = 0; i < num_particles; i++) { if (world->getRandomPoint(point, normal, velocity)) { if (length2(velocity) < spawn_threshold * spawn_threshold) continue; mul(direction, emitter_irotation, normal); spawn_particle(offset + Math::itof(i) * inum_particles, ifps, point, direction, velocity); } } Where normal is generated as 0, 0, 1 (since we have a horizontal plane here) and this is sent (unmodified in the end) as direction to spawn_particle. This is Unigine 2.13 is completely different behaviour than 2.5, for which I can obtain this as: Using Direction as 0, 0, 0 and Spread as 1, 1 and the particles move alongside the plane, as intended. So, what is the workaround for this (spawn particles on mesh surfaces and horizontally spread movement) for Unigine 2.13? Kind Regards, Adrian L. Link to comment
silent Posted April 19, 2021 Share Posted April 19, 2021 Hi Andrian, Thanks for the detailed description. This change can be caused by the big particles system upgrade in 2.12. Right now we are trying to reproduce it and get feedback from the dev team. As soon as we get more information we will surely let you know. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
adrian.licuriceanu Posted April 22, 2021 Author Share Posted April 22, 2021 Hi and thank you for your support! Any news or ETA on this? Do you have an workaround in mind? Link to comment
silent Posted April 22, 2021 Share Posted April 22, 2021 Hi Adrian, I'm afraid there is no possible workaround available. We hope that it would be fixed in the upcoming hotfix update next week. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
adrian.licuriceanu Posted April 22, 2021 Author Share Posted April 22, 2021 Oh, ok, good news then! Thanks! Link to comment
adrian.licuriceanu Posted April 22, 2021 Author Share Posted April 22, 2021 And one more question, we are currently stuck with 2.13 for few months while this patch is critical. Do you think you can provide the fix source code and I can try to apply it in old 2.13 source? Link to comment
silent Posted April 22, 2021 Share Posted April 22, 2021 adrian.licuriceanu Check your PM :) 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
