Ultralight Integration C# (Almost Complete)
Hey There,
Here is my repository for Unigine with Ultralight with c#: kireita/Unigine-Ultralight-Cs: UIltralight integration with Unigine (C#) (github.com)
if anyone can make it use the GPUDriver i would be very gratefull, for now it works only with Bitmap.
Here some samples:
  • Like 4
  • 8 months later...
Thank you so much !
I'm defintly looking into it, this is amazing.
Sadly I'm not so fluent with Unigine to inplement CEF / Webkit.
Following the development.
2 hours ago, Ugly1-1 said:
Really cool. Good work.
Is there a way to prevent the issue on resize? It's like the GUI doesn't adjust to fit.
On 1/5/2022 at 5:07 PM, PavlovTM said:
Thank you so much !
The  plugin is more a  PoC than an working plugin because :
The size issue can be solved by passing the window heigh/width to the Ultralight api and resizing the texture but some problems will appear like, you are going to get much lower FPS because you need to render on a bigger surface . The plugin works by updating pixels on a texture, this is brings ok performances for small textures but for bigger sizes you are going to get FPS like 30 or 25 so Isn't a viable solutions.
The best solution for this to work is to use shaders, you need to get the shapes and the data from ultralight and render it to a shader.
Edited by a.octavian
  • Thanks 1
