Joints and objects with high mass ratio
In documentation clearly stated that high mass ratios should be avoided with joints.
But if I really need to connect objects with masses up to 1:20. Is there something I can do besides using third-party physics solutions?
Like increasing iterations count (setNumIterations)? Or something like that?
Link to post
tower120
1:20 ratio should be possible to tune, the critical point is something around 1:750 and higher, which are not recommended.
You can increase iteration numbers, that should help to get more stability.
Link to post
