[SOLVED] Why there isn't a method to play the animations of skinned mesh reverse?
I see the ObjectMeshSkinned class has a "Play()" method to play the animations of skinned mesh.
Why there isn't a method to play animations reverse? Like "PlayReverse()" for example.
15 hours ago, silent said:
songtao.han
Can you show us your code? It looks like we can't reproduce this.
It's a component.
Here's playing the animation :
using System;
using System.Collections;
using Unigine;
[Component(PropertyGuid = "2b2f38e9cd42ad3423e877034df33086d433ce2d")]
public class AnimTest : Component
    private ObjectMeshSkinned Landgear;
    private void Init()
        // write here code to be called on component initialization
        Landgear = node.GetChild(node.FindChild("Landgear")) as ObjectMeshSkinned;
    private void Update()
        // write here code to be called before updating each render frame
        if (Landgear != null)
          if(!Landgear.IsPlaying)
            Landgear.Play();
And here's trying to play the animation reverse like the dude said upside but not working :
using System;
using Unigine;
    private void Init()
        Landgear.Speed = -1.0f;
            Landgear.Play();
2 hours ago, silent said:
More likely you need to increase the framerate of your animation to be more or less 30 fps:
Landgear.Speed = -30.0f;
It is working now. Thanks!
But you guys really don't think about adding a play reverse method?
  • silent changed the title to [SOLVED] Why there isn't a method to play the animations of skinned mesh reverse?
