How to pass data between components and AppWorldLogic?
Hi ,
I got a problem.
I have created a StructDeclaration.cs under the folder of source of my project. There is a struct like below in that file:
public struct ExternStruct
    public int data;
I need to fill this struct in AppWorldLogic like this:
public ExternStruct externStruct;
public override bool Init()
    externStruct.data = 147;
    return true;
Now here it the problem: how can I use the data of the struct in components? I write some code like:
private void Update()
     Log.Message("-> The data of extern struct is {0}(Component)\n", externStruct.data);
But it doesn't work.
Hi songtao.han,
You need to get a reference to your AppWorldLogic instance.
Use this in your component:
(Engine.GetWorldLogic(0) as AppWorldLogic).externStruct.data
Best regards,
Alexander
21 minutes ago, alexander said:
Hi songtao.han,
Best regards,
Alexander
I changed the code to:
        int data = (Engine.GetWorldLogic(0) as AppWorldLogic).externStruct.data;
        Log.Message("-> The data of extern struct is {0}(Component)\n", data);
		// write here code to be called before updating each render frame
But I got this:
Or, alternatively, you can use AppWorldLogic as a singleton:
class AppWorldLogic : WorldLogic
	// singleton design pattern
	private static AppWorldLogic instance;
	public static AppWorldLogic Get() { return instance; }
		instance = this;
		return true;
Then:
Log.Message("-> The data of extern struct is {0}(Component)\n", AppWorldLogic.Get().externStruct.data);
13 minutes ago, silent said:
Instead of Engine.GetWorldLogic(0) try to use Engine.GetWorldLogic(1). It looks like internal ComponentSystem Logic is used in this case.
Thanks! It works.
But I need to ask more.
If I write the code like:
AppWorldLogic.cs
public static StructDeclaration.ExternStruct externStruct;
    externStruct.data = 0;
    return true;
public override bool Update()
    externStruct.data += 1;
    return true;
Component
    Log.Message("-> The data of extern struct is {0}(Component)\n", UnigineApp.AppWorldLogic.externStruct.data);
It also works.
I want to know that can the code above cause some unexpected issue?
Only if you use more than one AppWorldLogic instance (if you use Engine.AddWorldLogic() method). :-)
