FBX Importer/Exporter incorrect rotation for cameras
Working back and forth with Blender to edit some FBX, I found that:
  • Unigine FBX Exporter will export cameras with a 90° vertical rotation added
  • Unigine FBX Importer will import cameras with a 180° vertical rotation added
As a check procedure, I imported and exported as FBX multiple times the same model with Blender, and no rotation was added on Blender side, so I guess the issue is on Unigine export/import.
Link to post
Hello Stephane,
Thank you for your detailed report, we successfully reproduced the problem and will fix it in future updates
Link to post
