Texture Atlas Size not saved
I have .Node file with a Particle System in it.
Any value entered for the Texture Atlas Size in the Particle System reverts to 4x4 after applying the node file.
I also can not see any values for this when I manually edit the .Node file in Notepad++
Is there a known work-around for this, or is there a reason for only allowing a 4x4 size?
(Editor used is 2.13.0.0)
Link to post
Hello Maran,
Actually it is a bug that Texture Atlas Size is not saved. Unfortunately, for now there's no workaround for this, but we'll fix this in upcoming 2.14 release
Sorry for the inconvenience caused
Link to post
