Console::setActive(true) doesn't work as expected
Tried this code to circumvent current limitation with keyboard handling in console management, but as explained in the code comments, it doesn't work as expected.
// Doesn't work. The console can be hidden, but never shown
if (App::clearKeyState(App::KEY_F1)) {
	Console::setActive(!Console::isActive());
// Doesn't work. The console cannot be opened with this.
// If the console is already open, then it will quick-close-open it again. (???)
if (App::clearKeyState(App::KEY_F2)) {
	Console::setActive(true);
// Works OK. Closes the console
if (App::clearKeyState(App::KEY_F3)) {
	Console::setActive(false);
// isActive Works ok, but strangely clearKeyState doesn't as it clearly auto-repeat keys
// based on OS setup. Shouldn't the key NOT auto-repeat? Or is there another fct for this behavior?
if (App::clearKeyState(App::KEY_F4)) {
	Log::message("active=%d\n",Console::isActive());
Also, Console::run("show"); doesn't work either.
Can you advise?
Edited by Amerio.Stephane
Link to post
Just showing/hiding the console through code
Link to post
