Unigine SDK 2011-08-12
Added AppWall template application that supports output to multiple devices. It can be used to create multi-monitor walls, deeply immersive VR simulators and multi-dimensional CAVE systems. Each output device can has its own camera setup. To control the number of monitors, include and customize data/core/scripts/wall.h script (check Wall settings that it adds into the main menu).
Render:
* Added multi-viewport output for all supported graphical APIs.
* Added screen-space reflection post-process (post_filter_reflection base material).
* Fixed WorldCluster rendering bug.
* Fixed portal bounds detection bug.
* Support of asymmetric projections throughout the whole rendering pipeline.
UnigineScript:
* A lot of performance optimizations.
* System and editor scripts now have render() function.
* Fixed the crash on detecting parent class of the exported classes.
* Fixed occasional crashes by script shutdown.
Physics:
* Increased performance.
* Fixed stack overflow in 64-bit builds.
* Contact solver now utilizes SSE instruction set, if available.
* Fixed gravity flag saving bug for bodies.
Mobile version:
* Added telnet protocol support (default TCP port is 8888) to remotely control the application running on a target device (it provides full access to Unigine built-in console). Use "logout" command to close the session.
* More NEON optimizations for rendering.
* Contact solver now utilizes NEON instruction set, if available.
* Performance analyzer for Android and iOS.
* Thread-safe file access to "assets" directory on Android.
* Added "Crypt" and "Passage" demos to iOS and Android SDKs.
* Added Android Application Development article in the reference manual.
PlayStation 3 version:
* SPU optimization of collision detection and rigid body physics.
* Added Render memory counter into the profiler.
* Improved memory management.
* Added new PS3MeshRaw object. It stores vertices and indexes in the video memory and doesn't cull triangles (higher memory consumption but lower PPU load).
* Render utilizes up to 4 SPUs (1 SPU is always reserved for physics).
Other:
* Added sound samples memory profiling.
* Fixed non-blocking network sockets bug in Windows.
* Added "Tools -> Always update" option in UnigineEditor for focus-independent update of the application window.
* Added a new option that allows to fast save the selected material/property libraries in UnigineEditor.
* HAS_TABLET define is renamed to HAS_APP_TABLET.
* Added Gui::HIDE callback for GUI widgets.
* Added new UnigineRender class into C++ API for direct access to engine rendering functions.
Download links
All files can be found in "Downloads" section of the portal: https://developer.unigine.com/fileserver/index
Very nice update especially for serious gaming/simulation applications ! Only missing feature in this field is more sophisticated node file streaming for really unlimited worlds.
Improved streaming will take some time for implementation, I guess it will be available in 1-3 months.
  • 5 weeks later...
