WarDuck 1 Share Posted January 16 (edited) Hi, I am trying to replicate a very small detail from my unity project to Unigine and it's causing a lot of trouble even tho I have seen the Third Person Demo Code it still is pretty unorthodox. Unity C# Script: Vector3 targetDirection = (Target.position - this.transform.position).normalized; Quaternion targetRotation = Quaternion.LookRotation(targetDirection, Vector3.up); transform.rotation = Quaternion.Slerp(transform.rotation, targetRotation, Time.deltaTime * RotationSpeed); This is a small script for turrents they rotate towards target. Unigine C# Script: vec3 targetdir = TargetNode.WorldPosition - node.WorldPosition; targetdir.Normalize(); quat targetRot = new quat(MathLib.LookAt(vec3.ZERO, targetdir, vec.UP, MathLib.AXIS.Y)); node.SetWorldRotation(targetRot); the results are not similar. I Did manage to get the desire result by a work around: vec3 targetdir = TargetNode.WorldPosition - node.WorldPosition; targetdir.Normalize(); node.SetWorldDirection(targetdir, vec3.UP, MathLib.AXIS.Y); but i still want to Limit Rotations i.e. so the turrent is not able to shoot if the target is right at top of it, so i guess i would need LookAt() nevertheless. Any clue what i might be doing wrong? Edited January 16 by WarDuck Link to post
karpych11 17 Share Posted January 18 Hello, In this case, you can use the WorldLookAt function of the node (https://developer.unigine.com/en/docs/future/api/library/nodes/class.node?rlang=cs#worldLookAt_Vec3_void). The LookAt function returns the viewing matrix, and it must be inverted to use it to get the desired rotation. Instead of LookAt, you can use the SetTo function (https://developer.unigine.com/en/docs/future/api/library/math/math.matrix?rlang=cs&words=lookat#setTo_constvec3n_constvec3n_constvec3n_int). Link to post
WarDuck 1 Author Share Posted January 18 Thank you @karpych11 the SetTo Function was exactly what I was looking for. Link to post
WarDuck 1 Author Share Posted January 18 (edited) Sorry for the follow up @karpych11 but There seems to be a tiny Issue. My Code is working as expected for the base of turret but the Pitch of Barrel is messed up at close distance. Unigine C# script: // pitch vec3 direction = TargetNode.WorldPosition - BarrelOfTurret.WorldPosition; direction.Normalize(); quat rot = new quat(MathLib.SetTo(vec3.ZERO, direction, BarrelOfTurret.GetDirection(MathLib.AXIS.Z), MathLib.AXIS.Y)); vec3 upRotation = MathLib.DecomposeRotationXYZ(rot.Mat3); vec3 baseRotation = MathLib.DecomposeRotationXYZ(node.GetWorldRotation().Mat3); // Zero Out Roll And set only pitch and Yaw BarrelOfTurret.SetWorldRotation(new quat(MathLib.ComposeRotationXYZ(new vec3(upRotation.x, 0, baseRotation.z)))); Unity C# script: //Pitch Vector3 direction = Target.position - BarrelOfTurret.transform.position; direction.Normalize(); Quaternion rot = Quaternion.LookRotation(direction, BarrelOfTurret.transform.up); Vector3 upRotation = rot.eulerAngles; BarrelOfTurret.transform.rotation = Quaternion.Euler(upRotation.x, transform.rotation.eulerAngles.y, 0); I have attached the Node/Game Object Structure Images as well. EDIT: I managed to get some result by simplifying the code It works as expected for now. quat rotationOfTurrent = new quat( MathLib.SetTo(vec3.ZERO, direction, vec3.UP, MathLib.AXIS.Y)); quat currRot; MathLib.Slerp(out currRot, BarrelOfTurret.GetWorldRotation(), rotationOfTurrent, PitchRotateValue * Game.IFps); BarrelOfTurret.SetWorldRotation(currRot); Edited January 18 by WarDuck Link to post
