ulf.schroeter Posted August 10, 2011 Share Posted August 10, 2011 Problem Double precision compile fails due to UNIGINE_DOUBLE define in file include/UnigineMathLib.h. I think it should be USE_DOUBLE as in the rest of the source code. ... #ifndef __UNIGINE_MATHLIB_H__ #define __UNIGINE_MATHLIB_H __ ... #ifdef UNIGINE_DOUBLE // most probably USE_DOUBLE #define UNIGINE_SCALAR double #define UNIGINE_VEC3 Unigine::dvec3 #define UNIGINE_VEC4 Unigine::dvec4 #define UNIGINE_MAT4 Unigine::dmat4 #else #define UNIGINE_SCALAR float #define UNIGINE_VEC3 Unigine::vec3 #define UNIGINE_VEC4 Unigine::vec4 #define UNIGINE_MAT4 Unigine::mat4 #endif ... Link to comment
steve3d Posted August 11, 2011 Share Posted August 11, 2011 use scons to build engine. I never met this problem. :D Link to comment
ulf.schroeter Posted August 11, 2011 Author Share Posted August 11, 2011 use scons to build engine. I never met this problem. :D We use VisualC++ 2008 for fast IDE programming/debug cycles and there this is an issue. BTW there is another issue when using utils/VCProj/unigine.bat. At least for VisualC++ 2008 the generated VisualStudio project files will fail during link both for debug/relase builds. We tracked it down to linker ignore_libraries template in unigine.py .... ignore_libraries = string.replace(''' libcmt.lib # this causes linker errors, fixed by removal of libcmt.lib from ignore_libraries ''','\n\t','') .... Link to comment
steve3d Posted August 11, 2011 Share Posted August 11, 2011 I used the IDE to compile the engine, but I got so many problems, so after that, I'll never use IDE to compile engine, use scons has no pains to compile :D Link to comment
ulf.schroeter Posted August 11, 2011 Author Share Posted August 11, 2011 I used the IDE to compile the engine, but I got so many problems, so after that, I'll never use IDE to compile engine With above described fixes you just have to Start utils/VCProj/unigine.bat once. This will generate a unigine.vcproj VisualStudio project file in folder source/engine. Open this project with VisualStudio and you can compile UNIGINE DLL without any problems. Add some dll copy operation as post-build step for transfer of newly build unigine.dll versions from source/engine folder to lib folder Configure bin/main_x86/64d.exe as debug application in project settings and than - bingo - you can edit, search, compile and debug UNIGINE engine completly from within Visual Studio IDE. Link to comment
