feheim 0 Share Posted Tuesday at 08:17 AM Hi, is there a possibility to get the RenderTarget (or Final Color Texture) used by Unigine::Gui? Our Setup is a follows: We use Unigine inside a Qt Application and use a Gui with WidgetSprites. The WidgetSprites themselves contain Overlays (Images) or Viewports. The Gui then generates the final image from all its children. The rendering happens through the use of the PlatformRender like in the ViewportQt Sample: platform_render->create(); platform_render->begin(); /* Render Viewports */ gui->enable(/* */); // Gui RenderTarget is bound --> clear it Unigine::RenderState::clearBuffer(Unigine::RenderState::BUFFER_COLOR, /* color vec*/); gui->render(/* */); gui->disable(); platform_render->end(); We found out how to clear the Color Texture through Unigine::RenderState::clearBuffer but now way to get TexturePtr or similar. The goal is to write the Buffer Date to an Image in order to write it to the disk. Thank you for any help! Link to post
rohit.gonsalves 39 Share Posted Tuesday at 08:56 AM Dear @feheim, You can create your own texture and render the gui on it. Then you may use that texture for any other reason you want. The following thing works for me. RenderState::saveState(); RenderState::clearStates(); RenderState::flushStates(); m_objTextureRender->enable(); m_objTextureRender->bindColorTexture(0, objTextureGUI); m_pObjWidgetCanvas->setPolygonColor(ID_GuiPoygon[iIndex], lerp( vec4(0.6f, 0.0f, 0.0f, 1.0f), vec4(0.0f, 0.4f, 0.0f, 1.0f), m_rAmount)); m_pObjWidgetCanvas->setTextText(ID_GuiText[iIndex], NAME_PIN_ChannelName[iIndex].c_str()); m_pObjWidgetCanvas->setTextPosition(ID_GuiText[iIndex], vec2(rStartPosX, rStartPosY)); ////Canvas Printing with additional Information m_pObjGui->update(Game::getIFps()); m_pObjGui->enable(m_vec2RenderSize.getValue().x, m_vec2RenderSize.getValue().y); m_pObjGui->render(App::getMouseX(), App::getMouseY(), App::getMouseButton(), 0); m_pObjGui->disable(); m_objTextureRender->flush(); m_objTextureRender->disable(); m_objTextureRender->unbindColorTexture(0); RenderState::restoreState(); RenderState::flushStates(); Now use objTextureGUI to save or draw. Hope this helps. Rohit Link to post
