Amerio.Stephane 23 Share Posted January 7 Hello, In 2.13.0.1, the View_Definition packet is not correctly applied if the IG runs in a Master/Slave configuration. Tested with a brand new IG project: With the default launch script (single channel), start HEmu or ig_host and manually send View_Definition packets: View type is correctly applied Left/Right FOV are correctly applied Reconfigure the project to add Syncker plugin, and modify the launch script to create a Master and Slave each with a different view ID (eg. 0 on master, 1 on slave) then restart HEmu or ig_host and manually send View_Definition packets: View type is applied only on Master Left/Right FOV are never applied, neither on Master or Slave This is currently BLOCKING us! If confirmed, a hot fix would be welcomed Thanks! Link to post
Amerio.Stephane 23 Author Share Posted January 7 Further testing done: with a single channel, if I add the command line "-sync_master 1", then the FOV is ignored even in single channel. This makes me think the issue is directly related to the Syncker. Link to post
silent 419 Share Posted Monday at 10:02 AM Hi Stephane, Thank you for the detailed description. This issue has been already fixed in the internal builds. Please check the PM, I've sent you an IG patch there. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to post
