Amerio.Stephane Posted January 5, 2021 Posted January 5, 2021 Hello, Quite often, I use in the Editor the Helper "Show Selected Node Info", eg. when tuning LOD distances or when evaluating a mesh density. But the text is centered on the bounding box of the object, and can block the view of quite a large part of the object sometimes. As the node info is only visible when only one node is selected, I would suggest you display it instead in the lower left corner, so it will not prevent viewing the mesh (or at least maybe make it an option). Thanks!
silent Posted January 11, 2021 Posted January 11, 2021 Hi Stephane, Thank you for the suggestion. I've added it to our internal features list with low priority at this moment. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
