materials_loading_mode impacting editor launch
Dear UNG support,
In default.boot, the setting materials_loading_mode set to 2 seem to impact editor launch time... significantly, if not simply prevent it from opening.
It is maybe normal; you clearly warm in documentation of that: "recommended to be used for production phase".
It is indeed useful with IG, but we currently still need to edit our worlds.
Would you recommend a way to deal with that?
Kind regards,
Charles
Link to post
Hi Charles,
Default materials_loading_mode is set to 1 for newly created projects (at least I couldn't find any case when it would be set to 2 by default). You can manually set it to 1 in config and override via command line start up options in the final build.
Can't see any issues here :)
Link to post
Thanks, good idea to put it as -console_command "materials_loading_mode 2".
You confirm it is overriding settings from default.boot..?
Kind regards,
Charles
Link to post
