Amerio.Stephane 26 Share Posted November 30, 2020 Hello, I found out that something triggered a rewrite of my ig_config.xml. I don't know exactly how it was triggered, but the problem is all <entity id="dis type"> have been rewritten in decimal form (ie without the x.x.x.x.x.x notation), making them illegible for a human. Could you fix that? Also, does this rewrite means all user XML comments will be lost? :( Bonus request: ig_debug and ig_debug_entity_info are TREMENDOUSLY useful! THANKS! But could you make it so the entity type name (from ig_config.xml) is also written? Would be the cherry on the cake :) Thanks! Link to post
silent 438 Share Posted November 30, 2020 Hi Stephane, We will take a look at the ig_config rewrite issue, but I'm not sure if we would have much time to improve debug output (however, sounds like a trivial thing to add). Thanks for the feedback! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to post
Amerio.Stephane 26 Author Share Posted December 2, 2020 The file ig_config.xml is overwritten right after the IG session started. The log show this (even on slaves): World loading "shared_MAR/ah_vdb_f_g.world" 1272ms Config::save: config ig_config.xml was modified WARNING: Manager::onWorldInit: geodetic_origin for database 2 was updated in ig_config.xml We need a way to prevent this, because it removes all comments (and sometimes, we just comment out some entities or parts of the file for tests). Or, there should be a way to load the xml with all its structure (and comments) and write back having touched only the part that you really needed to update. Link to post
silent 438 Share Posted December 2, 2020 That's already has been fixed in the internal builds. Will be available with hotfix update soon. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to post
