[SOLVED] Problem with the horizontal field of view
I am rendering trough the camera of my playerSpectator with a horizontal field of view of 60.0, I am calculating the vertical field with the following code.
	//FOV
	double aspectRatio = static_cast<double>(Unigine::App::getWidth()) / static_cast<double>(Unigine::App::getHeight());
	double fovhRad = fovh * M_1_PI / 180.0;
	double fovvRad = 2.0 * Unigine::Math::atan(Unigine::Math::tan(fovhRad*0.5) / aspectRatio);
	double fovv = fovvRad * 180 / M_1_PI;
	mpWorldLogic->getVisualizationSupervisor()->GetUnigineCurrentPlayerSpectator()->setFov(static_cast<float>(fovv));
	//Offset horizontal
	Unigine::Math::mat3 rotation_matrixX;
	Unigine::Math::mat3 rotation_matrixY;
	Unigine::Math::mat3 rotation_matrixZ;
	mpWorldLogic->getVisualizationSupervisor()->GetUnigineCurrentPlayerSpectator()->setRotation(Unigine::Math::quat(-90, hoffset, 0));
I am then applying an horizontal rotation (hoffset) to my playerspectator.
In brief, I'm rendering my scene with a horizontal fov of 60.0 then i am rotating of +60 degrees still with a field of view of 60 and the rendered images are not matching.
In the following images there is a little angle that is not covered by the any of the images.
How is it possible, what am I doing wrong ?
Link to post
setFov recalculate projection matrix with aspect ratio = 1
try to modificate
auto player = mpWorldLogic->getVisualizationSupervisor()->GetUnigineCurrentPlayerSpectator();
float znear = player->getZNear();
float zfar = player->getZFar();
Mat4 proj = perspective(fovv, aspectRatio, znear, zfar); // calculate projection matrix with right aspect
player->setProjection(proj);
	//Offset horizontal
  • Like 2
  • Thanks 1
Link to post
God bless you cash-metall !!
I've been scratching my head for quiet some time.
I also had to set my viewport setAspectCorrection to 0 to make it work.
Link to post
  • silent changed the title to [SOLVED] Problem with the horizontal field of view
