From syncker view name to IG view ID?
In ig_config.xml I can specify the CIGI view ID for a specific Syncker name. How do I retrieve the view ID from the name in C++?
<syncker_channels>
    <channel syncker_name="main"   view_id="0" use_syncker_projection="0"/>
    <channel syncker_name="sphere" view_id="1" use_syncker_projection="0"/>
    <channel syncker_name="pano"   view_id="2" use_syncker_projection="0"/>
    <channel syncker_name="ext"    view_id="3" use_syncker_projection="0"/>
</syncker_channels>
// I'm looking for something like this
IG::Manager::get()->getViewID("ext");
Link to post
Bonus question: How can I enumerate all listed syncker names and view_id in ig_config.xml (2.12)?
Link to post
Since 2.13 there is a method get getSynckerChannels and getViewTypes
const auto & syncker_channels = ig_manager->getConfig()->getSynckerChannels();
const auto & view_types = ig_manager->getConfig()->getViewTypes();
where you can change and save this blocks of ig_config.xml.
It looks like you are right, we need to add a method like
UPD: this is already exist getSlaveView("ext") since 2.13
Before 2.13 there is no way to get it. (except for manually reading the xml file).
Link to post
The name suggests it works for Slave. Will it work if the view is actually assigned to the master?
Link to post
yes it will.
return -1 if not found
Link to post
