[SOLVED] VR Teleport on Landscape terrain.
Hi, I'm pretty new to Unigine ( migrating from Unity ) so maybe it's something like a flag, but I don't know where I have to tick it :D
I was able to setup a project from the scratch, using VR plugin and prefab, and everything is fine.
I can use controller to teleport me on a plane, setting the proper intersection from editor for the plane and for the vr prefab.
But now comes the challenge, I have a new project created from Landscape Terrain, using just some height maps and basic albedo color. Everything is fine the location looks like we need, but unfortunately I was not able to set anywhere the intersection mask, to let the player teleport over the surface. I don't need restriction, I have to enable the player to teleport everywhere on the surface generated.
After playing a little bit I was able to flag on intersection for terrain, but now I see only red teleport ray, for not allowed teleport zone.
Any idea?
Edited by andrea.padovani
mark as solved
Hello!
As I can see you miss to match masks at ObjectLandscapeTerrain surface parameters here:
I'm sure this should help after the masks for your component and object start to match. Let's us know will it solve your problem or not.
4 hours ago, bmyagkov said:
Hello!
You gotcha!
Completely miss to check the surfaces tab, that's solve the problem! Now I'm able to teleport on generated terrain.
  • Thanks 1
  • andrea.padovani changed the title to [SOLVED] VR Teleport on Landscape terrain.
