Lales.Charles Posted November 11, 2020 Share Posted November 11, 2020 Dear Unigine team, Is there any way to control order of AppXxxLogic::init/update/shutdown? Usually main.cpp starts engine as follow: #ifdef _WIN32 int wmain(int argc, wchar_t* argv[]) #else int main(int argc, char* argv[]) #endif { // init engine Unigine::EnginePtr engine(UNIGINE_VERSION, argc, argv); // UnigineLogic AppSystemLogic system_logic; AppWorldLogic world_logic; AppEditorLogic editor_logic; // enter main loop engine->main(&system_logic, &world_logic, &editor_logic); return 0; } It is possible to declare multiple AppXxxLogic, call order will then follow add order. #ifdef _WIN32 int wmain(int argc, wchar_t* argv[]) #else int main(int argc, char* argv[]) #endif { // init engine Unigine::EnginePtr engine(UNIGINE_VERSION, argc, argv); // UnigineLogic AppSystemLogic system_logic; AppSystemLogic2 system_logic2; AppWorldLogic world_logic; AppWorldLogic2 world_logic2; AppEditorLogic editor_logic; // enter main loop engine->addSystemLogic(&system_logic); engine->addSystemLogic(&system_logic2); engine->addWorldLogic(&world_logic); engine->addWorldLogic(&world_logic2); engine->addEditorLogic(&editor_logic); engine->main(); return 0; } Then come in the game AppXxxLogic added through plugins. class InteractivePlugin : public Plugin { public: InteractivePlugin() { Log::message("InteractivePlugin::InteractivePlugin(): called\n"); } virtual ~InteractivePlugin() { Log::message("InteractivePlugin::~InteractivePlugin(): called\n"); } // plugin data virtual void* get_data() { return this; } virtual int init(); virtual int shutdown(); virtual void destroy(); private: InteractiveWorldLogic wl; }; int InteractivePlugin::init() { Log::message("InteractivePlugin::init(): called\n"); // add C++ callbacks Engine* engine = Engine::get(); engine->addWorldLogic(&wl); return 1; } I observed that InteractiveWorldLogic::init() is called before AppWorldLogic::init()... Is there a way to change that? Kind regards, Charles Link to comment
alexander Posted November 12, 2020 Share Posted November 12, 2020 Hi Charles! Is there a way to change that? Unfortunately, there is no way to change the order. I mean, there are no specific methods for this. All you can do is: 1) Add plugins in the AppSystemLogic::init() method via API (Engine::addPlugin), not the command line argument "extern_plugin". or 2) In the AppSystemLogic::init() use something like this: #include <Unigine.h> using namespace Unigine; int AppSystemLogic::init() { // world logic that needs to be pushed to the end of the queue WorldLogic *target_world; Engine *engine = Engine::get(); engine->removeWorldLogic(target_world); // remove from the middle engine->addWorldLogic(target_world); // add to the end return 1; } Best regards, Alexander Link to comment
Lales.Charles Posted November 16, 2020 Author Share Posted November 16, 2020 Hi, Thanks for feedback. In fact, the context was: AppWorldLogic::init -> create some players InteractiveWorldLogic::init -> use them (but null ptr) I solved it with kind of delayed init fired by event from camera controller... AppWorldLogic::init -> create some players InteractiveWorldLogic::init -> listen to cameraCtrl playerCollectionChanged InteractiveWorldLogic::playerCollectionChanged_callback -> use them But it fact, was simpler to move all players creation and usage in the same plugin init. Kind regards, Charles Link to comment
