Light in node reference question
Recently I ve noticed, that due to light depth texture baking, light cant be in node reference anymore, or in case of cloning this node shadows will go crazy. Is this intended behaviour? We have lots of nodes with light inside, typical case was torch. It was set once (mesh+light+particles) and then copied many times. It is not that big problem to put all lights out, but better to know if this is OK until we start. Thanks.
Edited by demostenes
Link to post
  • demostenes changed the title to Light in node reference question
Hi Jirka,
Unfortunately, this is expected behavior with static shadows and NodeReference. The shadow textures can't be set individually when the lights are inside the NodeReferences. If you want to clone the lights it's better to do it without placing them inside the NodeReferences.
There is a little chance that we can improve this behavior in the future, the functionality is quite fundamental and more likely will completely broke everything around :)
Link to post
1 hour ago, silent said:
Hi Jirka,
Thanks, I thought so, I just wanted to be sure :)
Link to post
  • 1 month later...
Hello, do I understand well, that this limitation also applies to light mapping? So In case I want to light map object with more instances, I cant use node reference?
Link to post
4 hours ago, silent said:
Yeah, the same thing. All the baked stuff is looks good, but brakes the batching.
Thanks! I think this info is worthy to be put in documentation.
Link to post
