dongju.jeong 6 Share Posted October 21, 2020 (edited) When calculating the HAT/HOT value directly by code, Is it correct to write like the following code? The test result is a little different. ( Code Result and HEMU Result) float angle = AppSystemLogic::ig_manager->findEntity(node)->getRotationEuler().z; Mat4 angleTransform = translate(node->getWorldPosition())* (Mat4)rotateZ(-angle); Vec3 pos0 = angleTransform * Vec3(2,1,-3); bool b0 = AppSystemLogic::ig_manager->getHatHot(AppSystemLogic::ig_manager->getConverter()->worldToGeodetic(pos0), vec3(), hat0, hot0, MatCode0); Edited October 21, 2020 by dongju.jeong Link to post
cash-metall 80 Share Posted October 21, 2020 Hello! its sample how to call hat/hot Vec3 offset = Vec3(1,2,3); int entity_id = 1; auto entity = ig_manager->getEntity(1); // auto entity = ig_manager->findEntity(node); // if (entity) ... Vec3 geo_position = ig_manager->getConverter()->worldToGeodetic(entity->getNode()->getWorldTransform() * convert->NEDtoENU(offset)); double hat = 0, hot = 0; Unigine::Plugins::IG::IGIntersection intersection; if (ig_manager->getHatHot(geo_position, hat, hot, intersection)) { // do smth } 1 Link to post
dongju.jeong 6 Author Share Posted October 21, 2020 (edited) Thank you.However, if worldtransform is used as it is, the HAT/HOT result value is affected by roll and pitch. Is this code wrong? Mat4 angleTransform = translate(node->getWorldPosition())* (Mat4)rotateZ(-angle); Edited October 21, 2020 by dongju.jeong Link to post
cash-metall 80 Share Posted October 21, 2020 5 hours ago, dongju.jeong said: When calculating the HAT/HOT value directly by code, Is it correct to write like the following code? The test result is a little different. ( Code Result and HEMU Result) 2 hours ago, dongju.jeong said: However, if worldtransform is used as it is, the HAT/HOT result value is affected by roll and pitch. according CIGI_ICD reference point must be in Entity Coodrinate system. that is why you have a difference in results. 2 hours ago, dongju.jeong said: Is this code wrong? Mat4 angleTransform = translate(node->getWorldPosition())* (Mat4)rotateZ(-angle); if you want calculate HAT/HOT witout affected by roll and pitch - yes, this code is right. but this may not match the result of the cigi hat/hot. I recommend using a visualizer to understand how raycast happens. Visualizer::renderPoint3D(pos0, 0.25, vec4::BLUE); Visualizer::renderLine3D(pos0 + Vec3::UP * 1000, pos0 - Vec3::UP * 1000, vec4::GREEN) Link to post
