detect rendered node/object
Is there a way to detect when a node/object is rendered or visible in the camera frustum?
I tried scouring the API but nothing pops up on the mentioned issue.
Link to post
Hi Silent,
I am looking for events to tap into in order to not hinder performance, something like these two callbacks in unity
private void OnBecameVisible()
private void OnBecameInvisible()
anything to avoid constantly checking for in the loop
Edited by Jeff_D
Link to post
Hi Jeff,
isVisibleCamera() check is pretty lightweight, so you if your use-case is to get some information about finite number of nodes (let's say hundreds) - you can use this method.
We are thinking of adding additional callback that will be fired when object is being rendered on screen (but more likely it would not be included in 2.13).
Link to post
Sounds good
Thank you
Link to post
