fabre.cedric Posted September 30, 2020 Share Posted September 30, 2020 Hello, I have a .node file that contains one mesh and one lightomni. When I use the hierarchyWorldBoundBox, the size of the returned bounding box is the <shadow_distance>100</shadow_distance> of the lightomni ?? It's a bug or maybe I made something wrong ? I use Unigine 2.12.0.2. Thanks Link to comment
silent Posted September 30, 2020 Share Posted September 30, 2020 fabre.cedric Could you please show us the full .node contents? What do you expect for the bounding box size of the light node? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
fabre.cedric Posted September 30, 2020 Author Share Posted September 30, 2020 Hi Silent, <?xml version="1.0" encoding="utf-8"?> <nodes version="2.10.0.0"> <node type="ObjectMeshStatic" id="1679715438" name="apc/Light Fixtures/Indoor Luminaires/Bulbs/Modern Bulbs/E27 Screw Base/Bulb 500 Lumens 001"> <mesh_name>core/meshes/15905575051590557505.mesh</mesh_name> <surface name="screwcap_default9" material="684fc1172aa9eb8a1b62e5616e523f4cca40723b"/> <surface name="bulb_default8" material="2b45f3a7195fdcda4996067160a74d1c556305cb"/> <surface name="bottomceramic_default4" material="81219d488bd6a0077ac6ddba5c0a51d102f760fc"/> <transform>1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1</transform> <node type="LightOmni" id="1733911815" name="LightOmni"> <attenuation_distance>60</attenuation_distance> <shape>0.01 0.01 0.01</shape> <shape_type>1</shape_type> <color_mode>1</color_mode> <intensity>10</intensity> <color_filter>0.04 0.04 0.025 0.2</color_filter> <shadow_bias>1</shadow_bias> <shadow_distance>100</shadow_distance> <fade_distance>10</fade_distance> <mode>0</mode> <shadow_mode>0</shadow_mode> <shadow_filter_mode>0</shadow_filter_mode> <shadow_filter>1</shadow_filter> <shadow_penumbra_mode>-1</shadow_penumbra_mode> <shadow_penumbra>0</shadow_penumbra> <lens_flare_enabled>0</lens_flare_enabled> <transform>1 0 0 0.0 0 1 0 0.0 0 0 1 0.0 0 0 0.12 1.0</transform> </node> </node> </nodes> I want only the boundingBox of the mesh not the light but when I write sceneNode->getHierarchyWorldBoundBox that return the size of shadow distance. Thanks Link to comment
cash-metall Posted October 1, 2020 Share Posted October 1, 2020 Hi! hierarchyWorldBoundBox works as expected. most likely you need something like this: void getMeshBoundBox(const NodePtr & node, WorldBoundBox &bb) { if (!node) return; int type = node->getType(); if (type == Node::NODE_REFERENCE) getMeshBoundBox(static_ptr_cast<NodeReference>(node)->getReference(), bb); else if (type == Node::OBJECT_MESH_STATIC || type == Node::OBJECT_MESH_SKINNED || type == Node::OBJECT_MESH_DYNAMIC) bb.expand(node->getWorldBoundBox()); for (int i = 0 ; i < node->getNumChildren(); i++) getMeshBoundBox(node->getChild(i), bb); } // and call it WorldBoundBox bound; getMeshBoundBox(node, bound); bound.getCenter()//... Link to comment
fabre.cedric Posted October 1, 2020 Author Share Posted October 1, 2020 Hi, I know this is possible to get the bound box in this manner. But I don't understand why the light return a bounding box because there is no vertexs in the light can you explain this choice ? Thanks. Link to comment
silent Posted October 1, 2020 Share Posted October 1, 2020 In case of light sources the resulting bounding box is calculated from the attenuation distance (basically, the distance where the light is still emit something or the light size): How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
