LouMatalka Posted September 27, 2020 Share Posted September 27, 2020 Hello, I have noticed the keypad key (numpad) are not defined in the KEY enum, how can I get input for those keys ? Thanks. Link to comment
silent Posted September 28, 2020 Share Posted September 28, 2020 LouMatalka Numpad keys are working like an arrows (at least 4 8 6 and 2). There is no specific numpad key codes, I'm afraid. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
LouMatalka Posted September 28, 2020 Author Share Posted September 28, 2020 (edited) 9 hours ago, silent said: LouMatalka Numpad keys are working like an arrows (at least 4 8 6 and 2). There is no specific numpad key codes, I'm afraid. Any reason for that ? they play a major part in the game I'm developing, I know they are not available on all keyboards/laptops, but is there a way to get input for them ? Edited September 28, 2020 by LouMatalka Link to comment
silent Posted September 28, 2020 Share Posted September 28, 2020 You can try to get numpad input via regular KEY_ enums (like KEY_DIGIT_1 for 1, KEY_PLUS for +; KEY_DELETE for , and so on). If NumLock is disabled you will recieve KEY_UP/DOWN/LEFT/RIGHT callbacks for 8 4 6 2 keys. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
LouMatalka Posted September 28, 2020 Author Share Posted September 28, 2020 7 minutes ago, silent said: You can try to get numpad input via regular KEY_ enums (like KEY_DIGIT_1 for 1, KEY_PLUS for +; KEY_DELETE for , and so on). That doesn't work, I've tried it (asuming you mean for example "Input.IsKeyDown(Input.KEY.DIGIT_1") Link to comment
silent Posted September 28, 2020 Share Posted September 28, 2020 I've checked keycodes in UnigineScript sample: SDK Browser -> Samples -> Script -> Widgets -> text_00. Here is the text that printed from NumPad (Unigine 2.12.0.2 SDK): How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
LouMatalka Posted September 28, 2020 Author Share Posted September 28, 2020 (edited) 4 hours ago, silent said: I've checked keycodes in UnigineScript sample: SDK Browser -> Samples -> Script -> Widgets -> text_00. Here is the text that printed from NumPad (Unigine 2.12.0.2 SDK): I've checked this out, I noticed both the numpad keys (specifaclly the numbers) and the alpha numbers (which is the numbers row above the letters) share the same code number (this is what the enigine.message is showing when pressing them in this sample code), for example the "0" key returns the code 48 and pressing the "0" key on the keypad also returns the code 48, I've attempted to create an custom method for the input wrapper to accept Int as a parameter instead of a Enum ( public static bool IsKeyDown(int key) ) and pass the code 48 to it, it only turns true if I press the "0" key that is at the number row and not the keypad, I've noticed that passing 0 to this function ( IsKeyDown(0) ) turns true if I press any of the numbers on the keypad (0 through 9) so I guess any key that is not recognised is interpreted as a code "0" but all other keys work in this custom method by passing their corresponding int code defined in the enum. What can I do about this ? Thanks Edited September 28, 2020 by LouMatalka Link to comment
LouMatalka Posted September 30, 2020 Author Share Posted September 30, 2020 On 9/28/2020 at 4:21 PM, LouMatalka said: I've checked this out, I noticed both the numpad keys (specifaclly the numbers) and the alpha numbers (which is the numbers row above the letters) share the same code number (this is what the enigine.message is showing when pressing them in this sample code), for example the "0" key returns the code 48 and pressing the "0" key on the keypad also returns the code 48, I've attempted to create an custom method for the input wrapper to accept Int as a parameter instead of a Enum ( public static bool IsKeyDown(int key) ) and pass the code 48 to it, it only turns true if I press the "0" key that is at the number row and not the keypad, I've noticed that passing 0 to this function ( IsKeyDown(0) ) turns true if I press any of the numbers on the keypad (0 through 9) so I guess any key that is not recognised is interpreted as a code "0" but all other keys work in this custom method by passing their corresponding int code defined in the enum. What can I do about this ? Thanks So is there a solution to this ? Link to comment
silent Posted October 1, 2020 Share Posted October 1, 2020 Could you please show us your current code that isn't working? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
LouMatalka Posted October 1, 2020 Author Share Posted October 1, 2020 (edited) 3 hours ago, silent said: Could you please show us your current code that isn't working? I've edited the Input class's function to receive int keycode instead of enum to try and check if there are keycodes for the keypad keys that aren't listed in the enum, here is it: { private void Update() { if (CustomInput.IsKeyDown(0)) { Log.Warning("Key Down!\n"); } } } public class CustomInput { public static bool IsKeyDown(int key) { return CustomInput.Input_isKeyDown(key); } [DllImport("UnigineWrapper_x64d", CallingConvention = CallingConvention.Cdecl)] [return: MarshalAs(UnmanagedType.U1)] internal static extern bool Input_isKeyDown(int key); } // For reference // /* SPACE = 32, // 0x00000020 EXCLAIM = 33, // 0x00000021 DOUBLE_QUOTE = 34, // 0x00000022 HASH = 35, // 0x00000023 DOLLAR = 36, // 0x00000024 PERCENT = 37, // 0x00000025 AMPERSAND = 38, // 0x00000026 APOSTROPHE = 39, // 0x00000027 QUOTE = 39, // 0x00000027 LEFT_PAREN = 40, // 0x00000028 RIGHT_PAREN = 41, // 0x00000029 ASTERISK = 42, // 0x0000002A PLUS = 43, // 0x0000002B COMMA = 44, // 0x0000002C MINUS = 45, // 0x0000002D DOT = 46, // 0x0000002E SLASH = 47, // 0x0000002F DIGIT_0 = 48, // 0x00000030 DIGIT_1 = 49, // 0x00000031 DIGIT_2 = 50, // 0x00000032 DIGIT_3 = 51, // 0x00000033 DIGIT_4 = 52, // 0x00000034 DIGIT_5 = 53, // 0x00000035 DIGIT_6 = 54, // 0x00000036 DIGIT_7 = 55, // 0x00000037 DIGIT_8 = 56, // 0x00000038 DIGIT_9 = 57, // 0x00000039 COLON = 58, // 0x0000003A SEMICOLON = 59, // 0x0000003B LESS = 60, // 0x0000003C EQUALS = 61, // 0x0000003D GREATER = 62, // 0x0000003E QUESTION = 63, // 0x0000003F AT = 64, // 0x00000040 LEFT_BRACKET = 91, // 0x0000005B BACK_SLASH = 92, // 0x0000005C RIGHT_BRACKET = 93, // 0x0000005D CARET = 94, // 0x0000005E UNDERSCORE = 95, // 0x0000005F BACK_QUOTE = 96, // 0x00000060 A = 97, // 0x00000061 B = 98, // 0x00000062 C = 99, // 0x00000063 D = 100, // 0x00000064 E = 101, // 0x00000065 F = 102, // 0x00000066 G = 103, // 0x00000067 H = 104, // 0x00000068 I = 105, // 0x00000069 J = 106, // 0x0000006A K = 107, // 0x0000006B L = 108, // 0x0000006C M = 109, // 0x0000006D N = 110, // 0x0000006E O = 111, // 0x0000006F P = 112, // 0x00000070 Q = 113, // 0x00000071 R = 114, // 0x00000072 S = 115, // 0x00000073 T = 116, // 0x00000074 U = 117, // 0x00000075 V = 118, // 0x00000076 W = 119, // 0x00000077 X = 120, // 0x00000078 Y = 121, // 0x00000079 Z = 122, // 0x0000007A ESC = 256, // 0x00000100 TAB = 257, // 0x00000101 BACKSPACE = 258, // 0x00000102 RETURN = 259, // 0x00000103 DELETE = 260, // 0x00000104 INSERT = 261, // 0x00000105 HOME = 262, // 0x00000106 END = 263, // 0x00000107 PGUP = 264, // 0x00000108 PGDOWN = 265, // 0x00000109 LEFT = 266, // 0x0000010A RIGHT = 267, // 0x0000010B UP = 268, // 0x0000010C DOWN = 269, // 0x0000010D SHIFT = 270, // 0x0000010E CTRL = 271, // 0x0000010F ALT = 272, // 0x00000110 CMD = 273, // 0x00000111 SCROLL = 274, // 0x00000112 CAPS = 275, // 0x00000113 NUM = 276, // 0x00000114 F1 = 277, // 0x00000115 F2 = 278, // 0x00000116 F3 = 279, // 0x00000117 F4 = 280, // 0x00000118 F5 = 281, // 0x00000119 F6 = 282, // 0x0000011A F7 = 283, // 0x0000011B F8 = 284, // 0x0000011C F9 = 285, // 0x0000011D F10 = 286, // 0x0000011E F11 = 287, // 0x0000011F F12 = 288, // 0x00000120 NUM_KEYS = 289, // 0x00000121 */ If you send "0" as a parameter to "CustomInput.IsKeyDown()" as shown above, you will receive input for all keypad keys from 0 to 9 and for other undefined keys such as Scrlk, Pause, Windows Key, and more, but this isn't a solution since I can't identify what key was pressed since they all share the same "Keycode" which is a keycode for undefined keys Thanks. Edited October 1, 2020 by LouMatalka Link to comment
silent Posted October 1, 2020 Share Posted October 1, 2020 As I already mentioned before, there is no way to find out if the key (for example '7') is pressed from numpad or from the default numeric part of the keyboard. Return codes will be the same for them. There is however a strange behavior with isKeyDown(0). It should not be triggered for the numpad keys, I guess. We need some additional time to check this behavior and understand if this is bug or not. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
LouMatalka Posted October 1, 2020 Author Share Posted October 1, 2020 (edited) 17 minutes ago, silent said: As I already mentioned before, there is no way to find out if the key (for example '7') is pressed from numpad or from the default numeric part of the keyboard. Return codes will be the same for them. I am fine with not knowing if the button was pressed from the numeric part of the keyboard of the keypad, but keypad keys won't work at all, for example, if you try out the following code: if (Input.IsKeyDown(Input.KEY.DIGIT_7)) { Log.Warning("Key Down!\n"); } or using my version: //DIGIT_7 = 55 if (CustomInput.IsKeyDown(55)) { Log.Warning("Key Down!\n"); } this will work only when pressing '7' from the numeric part of the keyboard, pressing '7' on the keypad won't work. Edited October 1, 2020 by LouMatalka Link to comment
silent Posted October 1, 2020 Share Posted October 1, 2020 Which SDK version are you currently using? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
LouMatalka Posted October 1, 2020 Author Share Posted October 1, 2020 1 minute ago, silent said: Which SDK version are you currently using? Unigine 2 Community 2.12.0.2 Link to comment
silent Posted October 1, 2020 Share Posted October 1, 2020 I've also tested this behavior with C# Component Samples (there is a world that demostrates input handling: csharp_component_samples\Input\Keyboard_And_Mouse). And it's working as expected: numpad.mp4 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
silent Posted October 1, 2020 Share Posted October 1, 2020 OK, I found the root cause of this behavior. What you currently observe is an engine bug. For some reason I thought it was fixed in the 2.12.x branch, but fix wasn't merged. This bug fix will be available in 2.13 release. Sorry for the inconvenience caused. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
LouMatalka Posted October 1, 2020 Author Share Posted October 1, 2020 13 minutes ago, silent said: OK, I found the root cause of this behavior. What you currently observe is an engine bug. For some reason I thought it was fixed in the 2.12.x branch, but fix wasn't merged. This bug fix will be available in 2.13 release. Sorry for the inconvenience caused. No problem, glad you found the issue. Happy to contribute with the development of this awesome engine! Thank you. 1 Link to comment
