[SOLVED] Light not passing through the semi-transparent objects
I had a scene of the room interior with semi-transparent glass on windows and seems they do not pass the sun light (LightWorld) through them. I then tried a simple test in editor, where I made a glass wall (alpha blending mode enabled and Albedo alpha set to 100) and put Omni light in front of it. I only see the light spot on one side of the glass. I expected it to illuminate the wall that is behind the glass, at least to some degree. When I enabled translucency, light spot appears on the other side, but still the light is not passing through it (the wall does not get illuminated). Could you tell me how to achieve this effect? Thanks!
Edited by elisagroup
Link to post
elisagroup
Looks like you need to disable Cast Proj and Omni Shadows option at the Common tab.
Alternative solution is to use additional State - Transparent Shadow.
But this approach may have some rendering artifacts.
Link to post
Worked like a charm, thank you, sir!
Link to post
  • silent changed the title to [SOLVED] Light not passing through the semi-transparent objects
