dongju.jeong Posted September 23, 2020 Share Posted September 23, 2020 Is there a way to register players already in the world as IViews of IG? // objects (create if it does not exist yet) virtual IView* getView(int view_id) = 0; There is a way to create IView in IG Manager, but I would like to register the camera created in advance in the Editor as IView. Link to comment
cash-metall Posted September 23, 2020 Share Posted September 23, 2020 unfortunately there is no easy way to do this you can apply Player's modelview and projection to View since 2.12 you can use ViewBase::copyTransformFromPlayer() // modelview View::copyDefinitionFromPlayer() // projection before 2.12 only through ViewBase::setPosition ViewBase::setRotation View::setDefinition 1 Link to comment
dongju.jeong Posted November 3, 2020 Author Share Posted November 3, 2020 hi. Do I have to copy post material separately? Link to comment
cash-metall Posted November 3, 2020 Share Posted November 3, 2020 materials will not be copied you need to use View::setType you can predefine type of view in the ig_config.xml <view_types> <view_type type="1" post_materials="post_sensor_heat"/> <view_type type="2" post_materials="post_sensor_green"/> <view_type type="3" post_materials="post_sensor_white"/> <view_type type="4" post_materials="post_sensor_red"/> <view_type type="5" post_materials="post_sensor_white,post_sensor_heat"/> </view_types> 1 Link to comment
dongju.jeong Posted November 4, 2020 Author Share Posted November 4, 2020 If I want to remove post material after using setViewType, what should I use? Link to comment
cash-metall Posted November 5, 2020 Share Posted November 5, 2020 19 hours ago, dongju.jeong said: If I want to remove post material after using setViewType, what should I use? I didn't understand what you want to do disable post materials? setViewType(0) 1 Link to comment
